Discussion topic: Technical fault with downloading a purchased film. Says try again later.
Message posted on 07 Jan 2024 11:51 AM
Technical fault with downloading a purchased film. No internet issues and tried resetting both box and mini box but no joy
Message posted on 07 Jan 2024 12:14 PM
Re: Technical fault with downloading a purchased film. Says try again later.
Are you able to view the film here via your online Sky Store account and then after selcting it, hit the download to box option:
https://www.skystore.com/n/mlbm/my-library/my-movies
If you get another error message then all you can do is to contact Sky Store support, if it helps they have a live chat that is available from 11.00am on Monday and can be found here:
https://www.skystore.com/help/contact-us
Message posted on 07 Jan 2024 02:16 PM
Thanks for this, I have tried to download from the link you sent and it won't let me do it either so I will contact the live chat tomorrow morning.
thanks again
