8
This discussion topic has been answered Discussion topic: Skystore.com purchases not transferring to Sky Q box
This message was authored by: Deco+diva
I have purchased several films from skystore.com via my iPad but they will not transfer to my Sky Q box - tried the restore movies, send to Q Box tried the suggestion to link sky store account but there is no tab for Find my TV!!. Oddly enough the 5 set Pirates of the Caribbean did appear briefly only to disappear again.  The ones I have purchased through my Sky Q box do appear on the sky store.com list.  Any ideas?  Really annoyed as I bought one yesterday to watch in the afternoon with friends then ended up having to buy it on Prime again so we could watch it.
This message was authored by: mike+simmonds Answer
Re: Skystore.com purchases not transferring to Sky Q box
Hi @Deco+diva
There are a few things you can try
First and maybe most obvious - check you are using the same Sky ID (email address) for both devices.
Then -,on your Sky Q box, search manually for the exact same movie that you can see on your IPad (same format / same version)
If everything has linked ok you should see that as "purchased - select to watch"  and not with a charge to select it
then that movie should soon appear in your Sky Q -menu under Recordings / Purchases
An alternative thing to try - when you see the movie in your IPad Skystore menu - do you not see a "send to box" option ?
oh - are your IPad and Sky Q box on the same WiFi ?
beyond those suggestions, you can chat with the Skystore support team here
https://www.skystore.com/n/hcus/help/contact-us
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
hi @Deco+diva
Were these purchses and not rentals ?
If rentals, then I believe these are different and you can't watch on a box if ordered via a device
https://www.skystore.com/n/lbtc/legal-bits/terms-and-conditions
Avatar for Deco+diva
No they were all purchases
Thanks for that @Deco+diva
Sorry I am not an expert but,  as you should see, I have moved your post to the SKY Store Specific group, as I think the regulars here may be better placed to help you with this
Thank you very much
Hi @Deco+diva
Sky Q 2TB main box
LG CX6LA from 2020
@Deco+diva
One other thing to check is if you online Sky Store account is linked to your Sky Q account:
1) Log into SkyStore.com
2) Go to your 'My Account' section
3) Go down to 'My Sky Account' and to the right of this follow the link for 'Link my account'
4) Input the correct details to correspond with your Sky TV account
If there is no link my account then it probably is already linked.
Thank you for your suggestion - there is no link account so I assume that I linked it a long time ago (can't remember). Have e-mailed Sky with the problem now, hopefully they will come back to me - I do not have the "mental strength" to listen to Sky's bot again let alone my stress levels when it hangs up on me!!
Hope it gets resolved @Deco+diva
I've always found the livechat team quite helpful and responsive
Sky Q 2TB main box
LG CX6LA from 2020
