Discussion topic: Sending purchased movies to sky box
Message posted on 20 Mar 2025 08:15 AM
I bought movies to watch on my iPad they download ok but when I want to watch on my tv it won't send them, it says sending to your sky box, icon turning round but I cannot do anything else it won't return back and I have to swipe the page off and start again. But it just will not send. I have sent other movies, is there a limit to how many you can send?
Message posted on 20 Mar 2025 10:06 AM
Re: Sending purchased movies to sky box
The only films that can be sent from your iPad to your Sky box are Buy and Keep ones so are these films these ones ?
Message posted on 20 Mar 2025 10:47 AM
Hi yes they are I have quite a few
Message posted on 20 Mar 2025 11:33 AM
I don't think there is a limit on the number of movies you can "send to box" @Sheels21
My thoughts would be to only send one at a time and also it often sorts out these annoying problems if you power off your Sky box at the mains for at least a minute (to allow the internal components to completely switch off) then power back on and try to send again
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Message posted on 20 Mar 2025 12:14 PM
If a reboot doesn't work thrn I would get in touch with Sky Store support regarding this, they have a live chat you can use that is available from 11am-7.30pm Monday to Saturday and can be found here:
https://www.skystore.com/help/contact-us
