12
This discussion topic has been answered Discussion topic: Ive purchased oppenheimer on my sky box but it is not showing in my purchases
This message was authored by: Jools59
Purchase not showing on sky box
This message was authored by: mike+simmonds Answer
Re: Ive purchased oppenheimer on my sky box but it is not showing in my purchases
Hi @Jools59
If you have a phone or tablet with which you can log in to Sky store. - try doing so and see if Oppenheimer is showing in your library.
If it shows online in your purchases you should also see an option to "send to box"
try that and then check your Sky box menu under recordings / purchases
in doing this - just be careful you don't click on anything which is trying to charge you again.
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Hi @Jools59
Try rebooting your Q box.
Avatar for Jools59
No that has not worked,is there a number I can call to speak with a human.Sky bot chat is awful
This message was authored by: Ecosse
To contact Sky, go to this link: https://www.sky.com/help/home
Scroll to the very bottom of the page and now select the Need More Help dropdown, this will lead to a phone contact.
Ignore the automated messages, just wait for an advisor
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Avatar for Jools59
Thankyou, is there not a free number to call on that you know of
Was this the Buy and Keep version that you ordered on the rental one ?
Avatar for Jools59
It was the buy and keep
If you back to the film on the Sky Store does it show as £0.00 for you allowing you to then access it ?
Did you get an email after you ordered the film ?
Avatar for Jools59
Hi,yes I did get a confirmation email and when I ho back to the store it shows £13-99 !!
There is not much you can do now as the Sky Store team doesn't work on Sundays so you could see if the Live Chat link here works tomorrow from 11am, if it doesn't then it will do on Tuesday the 2nd:
https://www.skystore.com/help/contact-us
Avatar for Jools59
Will do,thankyou
Hi @Jools59
Sky Q 2TB main box
LG CX6LA from 2020
Avatar for Jools59
I tried doing this on sky store.com but no joy,my son has since downloaded the app on my phone and low and behold it came up,so I've sent it to my skybox and we are ready to roll.Shame sky are so misleading, nevermind thanks for sll the help
