19
This discussion topic has been answered Discussion topic: Insufficient credit on viewing card message on movie rental using sky q
This message was authored by: Foggycat11
I am not able to view a downloaded movie because sky say I have insufficient credit on my viewing card. Problem occurred after removing viewing card and putting back. The card has paired ok and I have requested call back. No go!
This message was authored by: Lisa-P1987 Answer
Re: Insufficient credit on viewing card message on movie rental using sky q
Update - Spoken to Ashcoul, issue resolved by us resetting the purchasing limit. 🙂
Lisa - Sky Tech Team Expert
This message was authored by: Chloe-W22
Posted by a Sky employee
Hey @Foggycat11 ! Welcome to the Sky Community, click here to help get started...
Sorry to hear you're having an issue, this is something that needs updating in your account. I can escalate your post to one of our Community Messaging agents who will reach out and get that sorted for you here on Community 😊
Keep checking back here for a blue chat bubble appearing and for clarity here is some info on what our Community Messaging service is: https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Thanks,
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
This message was authored by: mike+simmonds
Hi @Foggycat11
As an alternative to the suggestion from @Chloe-W22 (most of her suggestions usually do work)  if there is any delay in contact and you wanted to get it fixed quickly - this can usually be sorted out with a live chat to the Skystore team (they should be open now for another hour if you can get through )
https://www.skystore.com/n/hcus/help/contact-us
It sounds like your credit limit may have  become reset to £0 and you will probably need to agree an amount with them to be registered on your account
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
This message was authored by: dmy24
Thank you for escalating this. We have sent an invite to chat 🙂
Avatar for Foggycat11
Have had two online chats. Card limit set to £100 but the problem persists. The issue has gone up the train of command but have had no resolution yet. I think I may need a replacement card.
This message was authored by: Mr+Flibbles+86
Update - THis has been resolved on a private chat
Thanks for confirming @Mr+Flibbles+86
Just to help with future similar questions  - was it a problem with the physical card or just something that needed updating at the Skystore end ?
Sky Q 2TB main box
LG CX6LA from 2020
Just an update need on our side for the account settings
After a long chat session I thought the problem was fixed. However the problem is back. I can download and watch films directly from the TV sky store but not from the sky+ app.
If you are trying to remote download a Sky Store film via the Sky+ app what happens when you try to do this, what error message do you see ?
At the top of the tv screen it says "the purchase cannot be completed as insufficient funds on viewing card. This is when I have used sky+ app to initiate the download.
That is odd, can you set the same download via your box itself ?
If so it might be worth double checking this with Sky Store support via the live chat when it opens at 11am:
https://www.skystore.com/help/contact-us
I wanted to watch the movie The Duke wit Jim Broadbent. It appears on app but not on tv. I also wanted to view The Electrical Life of Louis Wain which appears both on tv and the app. This appears to download from eithe tv or app. When I press play I get the insufficient funds message.
Let us know @Foggycat11 if you got through on live chat - or if you need another private chat - let us know and we can escalate it again for you.
Sky Q 2TB main box
LG CX6LA from 2020
This message was authored by: Ashcoul
Hi @Chloe-W22 @I am having the same trouble, please could you help 😊
