Discussion topic: I purchased a movie via Sky Store and it hasn’t appeared within Sky Store on my Q box.
This message was authored by: JR124
It was purchased on 23/11/23 - No Time to die
Re: I purchased a movie via Sky Store and it hasn’t appeared within Sky Store on my Q box.
If you login to this link @JR124 @can you see the film, if so select it as it should give you the option to send it to your Sky box:
https://www.skystore.com/n/mlbm/my-library/my-movies
Avatar for JR124
Many thanks @ceaserome
. Have followed that link and followed instructions to send to Sky Box.
Will soon find out if it appears...
This message was authored by: Barrett44
I purchased a film Birdcage but it's not showing on my new q box
@Barrett44
If it was a Buy and Keep film then try using the link in the post above to send it to your Sky Q box.
