20 Nov 2021 08:15 PM
I paid to watch the new James Bond film no time to die but there is no picture only sound with the download
20 Nov 2021 08:28 PM
Posted by a Superuser, not a Sky employee. Find out moreI'm just guessing here @Midge8Pinkie but are you watching on Sky HD and you're not on HDMI ?
If so, I don't think the Premiere rentals will work for you - (some sort of extreme copy protection )
If something else - let me know and I'll try to suggest something else
20 Nov 2021 10:14 PM
Posted by a Superuser, not a Sky employee. Find out moreAs @mike+simmonds has said @Midge8Pinkie you have to watch this on your main Sky+ box and no other TV connected to it because as you have found it will not work.
21 Nov 2021 01:43 AM
Exact same problem. Tried HD and then SD.
21 Nov 2021 09:47 AM
Posted by a Superuser, not a Sky employee. Find out moreAre you watching it on your main Sky+ box or if not where are you trying to watch it ?
21 Nov 2021 05:38 PM
Normal use of +HD box with TV which has worked for years with rented movies. It's clear from recent posts that something is wrong with this particular download, not the renters.
21 Nov 2021 07:31 PM
You are correct it has @grahamy0 but these are not your usual rental films, they are premier rentals and as such Sky has extra restrictions placed upon them by the studios and that is that they can not be viewed via a magic eye (or similar) and can only be viewed via a TV that is directly contacted to the Sky+ box.
