Discussion topic: Blank Movie Tiles on Sky Store Purchases - SKY Q Box
This message was authored by: SlimyBoo
Hi
I have found an issue on a couple of movie box sets I have bought from sky store when viewing in my 'purchases' section.
Only happend with 2 box sets out of a good number I have bought, but for some reason although the correct 'tile' or icon can be viewed in my purchases, a second 'blank' blue tile is slotted next to it and has all the movie info associated with it but if you select it, crashes the sky Q box.
Just wondered if there was an eay fix to get rid if these errors?
Cheers
Re: Blank Movie Tiles on Sky Store Purchases - SKY Q Box
It might be worth getting in touch with Sky Store support about this:
https://www.skystore.com/help/contact-us
Avatar for SlimyBoo
Hi - many thanks for the reply
I have been in touch with SkyStore Expert who has confirmed;
  •   I do apologise for that, unfortunately this is a simple glitch in the system, as this is not a registered purchase we cannot remove it, I do apologise for that.
  •  Unfortunately we haven't found a cause just yet but it might be patched out on a future software update
This message was authored by: Kets14
Have the same problem. Thanks for sharing.
