This discussion topic has been answered Discussion topic: wont move on from settings or skip & set up later
Message posted on 14 Aug 2025 09:14 AM
screen wording is Accessibility on sky Q
option to click on settings or skip & set up later.when tryvpick option nothing happens.
Message posted on 14 Aug 2025 09:24 AM
hi @romi5
This message seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only (so must have line of sight of the box)
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
hi @romi5
Message posted on 14 Aug 2025 09:32 AM
Re: wont move on from settings or skip & set up later
does nothing when pressing 4 & 6
