Discussion topic: upgrade from sky SD to skyQ
This message was authored by: mgrover75
hi to all
                today we phoned sky to upgrade from sky SD to sky Q because our sky SD channels will soon be switched off now we asked will the satellit dish and lmb be changed we have had sky for at least 20 years or more and our satellite dish is one that was first used by sky and installed now the person we talked to said that our satellite dish will not have to be replaced the engineer will just install the skyQ 2tb box and multiroom box is this correct
Re: upgrade from sky SD to skyQ
@mgrover75
The LNB will need changing. An engineer may change the dish if the current one is not working correctly or badly rusted.
The LNB has to be changed without doubt.
The dish will be replaced if necessary too.
hi @mgrover75
You may wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY +/HD to SKY Q
which covers this amongst many other things
Avatar for mgrover75
hi to all
               thank you for the info now the lmb that is fitted has only one coaxle cable coming from it and the lmb mounting slides into the arm see photo of lmb02160001.JPG
@mgrover75 wrote:
hi to all
@mgrover75
As mentioned by the others & in my notes SKY will replace that & renew the cabling & quite likely the dish as well
mk4 satellite dish
hi to all
                can anyone tell me what the length of the lmb arm that is on the mk4 satellite dish
Re: mk4 satellite dish
@mgrover75 wrote:
hi to all
Hi @mgrover75 I think it is around 80mm
sky dish adapter
hi to all
               my question is will the sky technician fit a adapter to my mk3 dish so that he can fit the lmb and do they carry the adapter on their van
Re: sky dish adapter
@mgrover75 wrote:
hi to all
hi @mgrover75
I am not too sure what you mean by a MK3 dish - is that an independent installed dish ?
SKY staff won't work with non SKY dishes
Are you thinking of upgrading from SKY +/HD - if so you may wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY +/HD to SKY Q
@mgrover75
Incidentally it's LNB, for Low-Noise Block downconverter.
https://en.wikipedia.org/wiki/Low-noise_block_downconverter
@mgrover75
Just to be clear if you need a new dish the engineer will fit one as part of the upgrade.
They won't upgrade the LNB on a non-SKY dish
hi to all
                it is a sky dish and it was installed over 20 years ago the LNB fits inside the arm and not like the mk4 over the arm and looking on the internet there is an adapter for the older dishes so that the sky q LNB can be fitted to the older dishes and i was wondering if the technition will supply this adapter
@mgrover75 wrote:
hi to all
Hi @mgrover75
As previously posted on numerous occasions just forget about the adaptor as a complete new dish can be installed.
sky plus LNB and dish
hi to all
               i have sky plus so does sky q use the same LNB and DISH
