Discussion topic: u s open tennis
Message posted on 22 Aug 2023 11:21 PM
u s open tennis
how can you watch all of the us open tennis matches with sky
ive added sky sports to get the arena but you can not choise the matches you want to watch only what is on
Message posted on 22 Aug 2023 11:57 PM
Re: u s open tennis
This article below may help
not all the games may be been broadcasted but that article should hopefully help you out
Message posted on 23 Aug 2023 05:46 AM
Re: u s open tennis
This week is qualifying week and only one screen is available - but when the competition proper starts next week you should be able to access all courts on SkyQ.
@darrenly2020 wrote:how can you watch all of the us open tennis matches with sky
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
Message posted on 28 Aug 2023 04:53 PM
Re: u s open tennis
How do I access the other tennis courts coverage. I pressed the red button but it doesn't go anywhere
Message posted on 28 Aug 2023 05:00 PM
Re: u s open tennis
As discussed in another thread on here;
From red button you are as you say taken to the ranking page (no idea why),, hit the sky remote backup key.
That puts you on the court choice line, scroll left for the 17 or so courts.
Choose the court with select.
Use select when it shows watch live.
To return to the stream choice, while watching a stream, choose select and back button and scroll either left or right for other streams.
Message posted on 28 Aug 2023 05:01 PM - last edited: 28 Aug 2023 05:02 PM
Re: u s open tennis
hi @croftwoman
Do you get the rankings list when you press the Red button or just nothing
If nothing try a reboot of your SKy Q Box (place in Standby, then unplug & wait >15s before re-applying power)
If you get the rankings then press the back/duismiss button which should then bring up various courts and other options which you may hev to scroll through
Edit : @lettice has probably described the action needed better
Message posted on 28 Aug 2023 08:36 PM
Re: u s open tennis
How do we watch the matches on demand? Given that we are based in the UK and the US Open is a different time zone, how can you choose a match to watch On Demand the following day? You need a proper player like Eurosport and Prime. Otherwise it will be incredibly disappointing...
Message posted on 28 Aug 2023 09:37 PM
Re: u s open tennis
Yes hope they sort this out very poor service for the extra cost sky charges than prime which was a must better service and had a watch list and you could watch things back , this is rubbish they say you can use now tv but not paying anymore if sky can not get it put right.
Message posted on 28 Aug 2023 10:28 PM
Re: u s open tennis
I know. I can't find a way to watch on demand. Surely they have this facility? I want to come in from work and be able to look for the match I want that was on earlier in day. Or watch the Coco Gauff match that starts at midnight UK time tomorrow during the day.
Am I missing something? can't see anything on demand. Can't pause stream, FF or view from start of match.
Sharon
Message posted on 28 Aug 2023 10:29 PM
Re: u s open tennis
I just upgraded to SkyQ from an old box specifically to upgrade to SkySports for the US Open. the tech isnt coming for 2 weeks! Can I install it myself? Can I only watch it on my phone on the app?? Do I have 14 days cooling-off period to cancel?
Message posted on 28 Aug 2023 10:46 PM
Re: u s open tennis
Have a look in My Sky app to see if sooner appts - cancellations come up.
When I switched from Sky + HDbox to Sky Q in 2020 I recall it needed the chap to come with the new Sky Q 1TB box plus you need different ports on the satellite dish fitted. Annoyingly the Sky + box recordings can't be transferred over either so make sure you watch all saved recordings that you don't want lost!
hope that helos
Sharon
Message posted on 28 Aug 2023 11:25 PM
Re: u s open tennis
You should be able to record the night sessions from tv menu on arena or active just not ones on red button
Message posted on 28 Aug 2023 11:31 PM
Re: u s open tennis
Omg, you can't transfer any saved recordings???!😔
Message posted on 28 Aug 2023 11:33 PM
Re: u s open tennis
Do you mean record the entire program and fast forward through to the ones I want? I don't think they're showing all.😔
Message posted on 29 Aug 2023 12:02 AM
Re: u s open tennis
Unfortunately no. It's ridiculous. Why can't they save your recordings on viewing card but instead they save on box so once changed to Sky Q you can't use Sky +HD box
