Discussion topic: to change from hdm1 to 4 0n skyq box
Message posted on 21 Jul 2024 07:57 AM
in order to connect to my amazon firestick i need to change my tv from hdmi1 to 4 is this possible to do this on sky q remote without having to go on tv remote as it seems to go crazy
Message posted on 21 Jul 2024 08:01 AM - last edited: 21 Jul 2024 08:03 AM
Re: to change from hdm1 to 4 0n skyq box
hi @gabrielle1
You should be able to do this using the 'Input' button on the SKY Remote which is at the top right of the most recent remotes (looks a bit like an old TV screen with arrow pointing in from the left).
Each press should cycle throgh the different Inputs on your TV so you will need to press a few times
BTW If your TV & Firestick are set to use HDMI control (which usually they are ) pressing the FiresticK Home button would also change over to it
Message posted on 06 Feb 2025 09:15 AM
you cant scroll through the imputs - it shows them on the screen but no buttons actually change from your existing source.
Message posted on 06 Feb 2025 09:36 AM
Changing input with a Sky remote isn't entirely reliable because television manufacturers implement this feature in different ways.
The remote for the Stream puck has no input button at all.
Message posted on 06 Feb 2025 09:37 AM
Message posted on 06 Feb 2025 12:15 PM
@MightyQuinn wrote:
@alesis wrote:you cant scroll through the imputs - it shows them on the screen but no buttons actually change from your existing source.
Hi @alesis For the vast number of quality TVs, each press of the button should move the selection down one.
That's how it works on my Sony TV, each press goes to the next input. When it gets to the one I want, I stop pressing & the TV then switches input & the TV's selection menu closes.
Message posted on 07 Feb 2025 10:00 AM
thanks all but my Phlips OLED doesnt change imputs no matter what button I press.
