Discussion topic: the picture is dark blue
Message posted on 25 Aug 2023 05:34 PM
The picture is dark blue. I have checked the hdmi cable, changed the port on the tv and reset it a number of times, no change
Message posted on 25 Aug 2023 05:36 PM
Re: the picture is dark blue
Hi @JanetS
