Discussion topic: syky Q wireless connection drops out every few minutes.
This message was authored by: Quser86
Sky Q wireless connection drops out every few minutes. No problem with UW router. has been ok for months.
Re: syky Q wireless connection drops out every few minutes.
Hi @Quser86
Have you carried out a Network Reset on the main Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
As you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
