Discussion topic: sound problems in last couple of weeks
Message posted on 15 Feb 2025 07:56 PM
In the last few days or so the sound quality on my sky q box has become very poor - it has lost its quality and is very tinny. It is even worse on recorded programmes. I can turn the sound right up from my normal 15 / 16 up to 40 plus and it is still awful. I have checked software update and have tried turning it on and off. Sound on my TV through normal none sky programmes is fine.
have had the kit for many years with no problem. we have a sony oled tv.
is it time for an engineer but i am at a loss how to contact them these days as i cannot find a number.
many thanks
Message posted on 15 Feb 2025 08:00 PM
Re: sound problems in last couple of weeks
many thanks
Hi @bikerdave1
Message posted on 15 Feb 2025 10:02 PM
It seems extremely unlikely the sound would be affected like this unless a setting on the TV has changed for that input.
Message posted on 16 Feb 2025 09:38 AM
Thank you so much for your speedy replies. The problem is strange - no settings on the TV have been changed and the picture is really good. It is just the quality of the sound - especially on play back. It does seem ok when we first switch it on and then it gets worse over time until we are having to turn the sound up very high. I did wonder if there had been a software update that might have affected the sound.
I might call in an engineer as i am not overly confident about accessing hidden menus!
thanks again
Message posted on 16 Feb 2025 11:27 AM
Have you tried changing the hdmi audio out to just stereo? (that one is not in the hidden menu and honestly on the sky box the hidden menu is not very techie anyway)
The fact it changes over time is very weird.
Message posted on 16 Feb 2025 12:46 PM
Hello and thankyou for your reply. I have checked to audio setting and it is on Dolby Digital, we do not have a sound bar. I changed it to normal which was the only other option. There is no significant change but I will keep the normal setting and see how we get on. My only thoughts are that it must have been on DD for years as I have never changed this setting but fingers crossed it might work.
Message posted on 16 Feb 2025 05:18 PM
TV can clearly decode dolby digital but yeah, try normal for a bit.
