Discussion topic: slow changing channel or sky q goes completely off then need to restart
Message posted on 23 Jun 2024 09:48 PM
having trouble changing channel or the sky q would go off completely with the remote control but bought a new one but it is still happening. This is been going on for 2 weeks hope you can help
Message posted on 23 Jun 2024 10:20 PM
Re: slow changing channel or sky q goes completely off then need to restart
Hi @cyril1
