Discussion topic: sky to apps stop working after upgrade to sky ultra briadband
Message posted on 15 Dec 2024 02:13 PM
has anyone had an issues with apps after changing to sky ultra broadband
I have to keep reloading and reconnecting internet connection,apps stop while watching then i have to reconnect the broadband again,
it's quite annoying
Message posted on 15 Dec 2024 04:02 PM
Re: sky to apps stop working after upgrade to sky ultra briadband
What devices are these apps installed on ?
Message posted on 15 Dec 2024 04:04 PM
It's the bbc iplayer and netflix on the main sky q box, i can't even connect my 2 extra boxes upstairs or in my outbuilding that we use as a sports bar
Message posted on 15 Dec 2024 04:31 PM
As this isn't related to mobile apps (where you had posted) I have moved this to the Sky Q forum for you.
Message posted on 15 Dec 2024 04:55 PM
Hi @ktsavage
If you have the Sky Max router first try connecting by SSID and Password and not WPS.
Hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Wait until the router is completely back and running and then try a Network Reset found in the main Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to 3rd party router
Enter the SSID and password for the router 2.4 Ghz WiFi band.
If this gives your main Q box a stable Network connection then you will need to connect all minis by WiFi to your main Q box using WPS
