4
This discussion topic has been answered Discussion topic: sky q wont connect to hub I have pressed hub button for 5 seconds then pressed button on sky q
This message was authored by: jackiep71
My sky q wont connect to my wireless hub . I have pressed wps buttin on hub then pressed wps on front of sky q box
This message was authored by: Laing1 Answer
Re: sky q wont connect to hub I have pressed hub button for 5 seconds then pressed button on sky q
@jackiep71 wrote:
Yeah all with sky
@jackiep71 I have found myself that it has taken 3 or 4 attempts on occassions don't know how many times you have tried
Is it possible to move the router or Sky box closer to each other to see if they will connect then move them back to where you currently have them ? Worth a try if its possible to do this.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@jackiep71 i am guessing that if you are trying to connect by WPS then your broadband provider is Sky ?
Avatar for jackiep71
Yeah all with sky
@jackiep71 wrote:
Yeah all with sky
Thank you ive tried lits since Sat. my hub is connected away up stairs so no chance of closer
