Discussion topic: sky q repeatedly disconnects from sky router
This message was authored by: fed+up+with
had sky q fitted a week ago.
the sky q box repeatedly disconnects from the router and hence the internet.
I have to go through the reset process everytime and it is starting to annoy me.
none of the other devices on the internet are affected just the new sky q box.
i cannot record anything reliably or do other things that require the internet to work.
feel like i have made an error in swapping from sky+ which was never an issue.
it has got to the point where i do not watch anything anymore and want it gone.
Re: sky q repeatedly disconnects from sky router
Hi @fed+up+with
how far is your Q box from your Sky Router?
Also exactly what are you doing when you say Reset process?
Avatar for fed+up+with
q box downstairs router upstairs.
following instructions on sky q box.
no other items downstairs are affected.
2 phones,laptop,internet radio and had no issues with sky +.
What instructions @fed+up+with
That does really explain exactly what steps you are taking
tells you on sky q box what to do.
go to settings,network settings and follow reset process.
So what WPS buttons are you pressing @fed+up+with ?
on the router.
@fed+up+with wrote:
on the router.
OK @fed+up+with
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Wait until the router is completely back and running and then try the Network Reset again.
when you are asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
done all that still disconnects
@fed+up+with
If you haven't already try Reset Settings in the Q box hidden menu.   It may help.
Failing this it looks like you need a Sky Q booster between the router and the main Q box.
will call sky tomorrow and tell them to come take it out.
