Discussion topic: sky q miniboxes are ok but main sky q box is showing white screen and scratchy images
This message was authored by: gary155
I have replaced the HDMI cable and tried different ports on my TV but no picture. My Firestick and DVD player work perfectly so assuming Sky box issue.
Avatar for gary155
Re: sky q miniboxes are ok but main sky q box is showing white screen and scratchy images
.....to add, both my mini boxes work perfectly well
Hi @gary155
Have you tried rebooting your Q box?
Failing this, if you get into your Q box Home menu,
Avatar for gary155
Thank you for your support. I have tried rebooting a few times and I still get a white screen with outlines of faces etc. I cannot get into settings because I cant see them because  the screen is a white out. It isnt a tv problem because other HDMI and usb products work perfectly. and I have 2 miniboxes in adjacent rooms that work ok.
I will get an engineer out although the earliest date is next Wednesday!
Thanks again (another oldfella)!
