Discussion topic: sky q box keeps losing wifi connection
Message posted on 02 Oct 2023 06:20 PM
Hello my sky q box keeps losing wifi connection all the time. Please help
Message posted on 02 Oct 2023 06:53 PM
Re: sky q box keeps losing wifi connection
Yep happened to mine for over a year, have now got a new box and badda bing, one week later, dumped again and NO sky, my internet is fine!!!
Message posted on 03 Oct 2023 11:09 AM
Hi there @Priya77 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Lisa - Sky Tech Team Expert
Message posted on 03 Oct 2023 11:27 AM
I am having the same issue. Sky Q main box lost connection (afternoon 2 Oct) and won't reconnect rendering my mini boxes useless!
I have tried all the suggested fixes, many times, and still won't connect.
My router is working fine, as are my laptops and phones. Very frustrating!!
Message posted on 11 Oct 2023 10:23 AM
Hi have same issue . Sky 1tb Q box. Worked fine until I had fibre installed and a mini box now dropped out twice in last 2 weeks and had to reset and re do WPS to reconnect
Message posted on 06 Nov 2023 01:51 PM
I have the same issue where we can't access apps as it says no connection. We have tried everything but only temp fix is to reboot box but this sometimes only works for a few minutes. It's very frustrating and means we can't watch what we want when we want. Please help.
Message posted on 26 Feb 2025 07:13 PM
I have the same problem with my sky q box. For some reason it is connected but says it isn't. I can either reboot the sky box which then works without changing any settings. Or I remove and reconnect the WiFi entering the router password.
I tried a cable connection and it just doesn't do anything. Router says there isn't anything connected with a cable.
Not sure how to solve the problem
Message posted on 27 Feb 2025 05:51 AM
I am having the same problem with my mini Q box, every morning I have to go through the process of reconnecting to the main box & takes a couple of attempts.
both boxes are connected to sky broadband wirelessly
Message posted on 27 Feb 2025 06:03 AM
See this link. The time you've posted suggests maybe your stand-by settings need changing to None
https://www.sky.com/help/articles/using-the-standby-settings
