Discussion topic: sky q box has error message saying "Please insert your viewing card with the chip facing up" help ha
This message was authored by: StevPDa
I am getting the Sky Q error message "Please insert your viewing card with the chip facing up . I have followed the online help and have tried reinserting the card and I have completed a re-boot. I then called Sky (which lasted 30mins) where I was told to do the same again, which didn't help. I was then told to wipe the card with a cloth, which I did and still did not work. I then got passed to a Sky Q adviser who told me they had reset the card and it should work within 4 hours. That was 12 hours ago and it still doesn't work. Any ideas?
Re: sky q box has error message saying "Please insert your viewing card with the chip facing up
You may well need a new card sent to you.
You'll have to call Sky for that.
This message was authored by: EveS
This box does not have a card  so msg is strange
@EveS if its your main Q box then there is a card it on the right hand side of the box toewards the front there will be a few millimeters of the card sticking out
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
All sorted now, spoke to a very nice man
This message was authored by: tronaster
SkyQ is not working and this messge comes up - redone this as instructed but no avail
@tronaster You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
This message was authored by: Morxx
Thanks Laing1, followed your instruction and it worked perfectly
This message was authored by: Aquarian3
THANK YOU!!!!!  This post made my viewing card work again and all done without having to explain the issue on the phone after waiting an age to get through to a human, so I appreciate you very much ❤️ 🙏
This message was authored by: Cins
Thank you so much.  Tried what you suggested collectively and it worked
Am  so grateful.  Watching the footie and don't want to miss end
