Discussion topic: sky plays in a small screen in Home Dashboard but not on big TV screen
Message posted on 03 Nov 2024 10:59 AM
I can't connect TV to Sky by pressing on HDMI1. Message on screen - Not Programmed
But it plays in small screen when I connect via Home Dashboard
Message posted on 03 Nov 2024 11:08 AM
Re: sky plays in a small screen in Home Dashboard but not on big TV screen
The not programmed message is from your TV's internal Tuner so I am not sure why it is apearing when you select HDMI1
Again the appearnce of SKY in a small window also indicates your TV settings.
May I suggest checking your TV settings using the TV's own remote & maybe even consider doing a full power down restart of your TB (unplu/switch off at mains)
