4
This discussion topic has been answered Discussion topic: sky mini box stopped working when my TNT subscription with BT ended.
This message was authored by: BrashBaz
Getting message telling me to check my subscription entitles me to view this channel on this box. No channels not even Free to Air.
Avatar for BrashBaz
This message was authored by: BrashBaz Answer
Re: sky mini box stopped working when my TNT subscription with BT ended.
Thanks @oldfella Tried that but didn't work.
Left it for a while just incase it needed time.
Just off the phone to Tech Help.
All working now.
With an Upgrade and a bit cheeper.
Thanks for taking the time to try to help @oldfella
Hi @BrashBaz
Reboot the mini as above.
Avatar for BrashBaz
Thanks @oldfella. But no differince. Says Mini Box Is connected. Could it be my viewing card needs updating? Settings says I have Multi Box.
Baz
Baz
Hi @BrashBaz
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Avatar for BrashBaz
All working now.
