Discussion topic: sky mini box goes blue at least once every evening for last two weeks
This message was authored by: notemailsavvy
We turn off and it comes back on, but its inconvenient and as this has been going on for two weeks. Some evenings it goes blue two, three times. Do we need a new box? We have had the mini box foe at least five years. If we do need a new box, can I have the number or email of the depeartment that I need to contact please? Thanks
Re: sky mini box goes blue at least once every evening for last two weeks
Hi @notemailsavvy
Reboot the mini as above.
