sky box noise since update
Runner
Post 61 of 73
Re: sky box noise since update
Is anyone still experiencing problems on 1 Tb box? My recordings failed yesterday and the fan noise is driving me mad.
Executive Producer
Post 62 of 73
https://helpforum.sky.com/t5/Sky-Q/Noisy-box-again-Sorry/td-p/2814428/page/7
BT Ultra Infinity. Apple Time Capsule. Sky Q 2TB watching UHD through a LG OLED55B7 and listening through a soundbox. Multiroom with 2 miniboxes
Runner
Post 63 of 73
My sky box is awful. I can't bare to be in the same room as it.
Runner
Post 64 of 73
I have a 1TB Sky Q box. After my last post I rang SKY and they said they were not aware of noise issues with the Q boxes however sent engineers out who agreed very noisy and replaced the box. Whilst not perfect this box is definitely quieter although he had to try more than 1 box.
Producer
Post 65 of 73
Given the bug in the 1TB box and the lack of a time-frame for when it's going to be fixed, I'd have asked to be swapped with a 2TB box.
Sky Q 2TB V1 -- LG 55UH850V UHD TV -- 1 Mini
Runner
Post 66 of 73
Ours has been noisy from day1 - and it seemed clear that it was a design fault as so many people complain. I have three copper heatsinks resting on top which quieten it down a bit but it is still annoying..
Producer
Post 67 of 73
Do you have a 1TB or 2TB box? The 1TB box had a firmware bug that causes the fan to run constantly.
Runner
Post 68 of 73
I forgot to say this is the base box. (1TB IIRC).. it does have the latest update
Executive Producer
Post 69 of 73
There appears to have been a bug in the software update sent out in October that’s causes the fan to run all the time, hopefully it’ll be resolved at the next update
Producer
Post 70 of 73
You have three choices to deal with the noise.
1. Get the box swapped for a quiter box
2. Upgrade to a 2TB box
3. Put up with it
I'd go with 2 as the 2TB box is much better. But it will cost something to swap.
Series Linker
Post 71 of 73
I’ve had the same issue with my new Sky Q box. The humming was so loud I could here it over programmes and also from the kitchen when the TV was turned off.
After a bit of experimenting, I raised the box off the wooden shelf it was standing on in the TV cabinet - a conker under each corner!! - and the humming stopped completely.
It must have been the shelf amplifying any vibrations in the box.
Not a highly technical solution but very cheap and simple 😁
Executive Producer
Post 72 of 73
If you look on e bay you can buy rubber feet for the Q box should your conkers fail
New Viewer
Post 73 of 73
My Q box is doing the same and its diving me mad.
Recommended Threads
7 minutes ago 02:59 PM
Oracle 11 minutes ago 02:55 PM
11 minutes ago 02:54 PM
Oracle 16 minutes ago 02:49 PM
20 minutes ago 02:46 PM
