Discussion topic: samsung t.v and sky remorte
This message was authored by: Chris325
samsung t.v model not listed used all options available, can get the remote to control volume but not able to power t.v on or off
Re: samsung t.v and sky remorte
Hi @Chris325  Try pressing the remote power button for 3 sec to turn off your TV?
Avatar for Chris325
thank you. screen goes black after 3 seconds but then starts uop again
Hi @Chris325
Looks like you are holding the Q remote power button for too long.
You must release it immediately after 3 secs or the TV will reboot.
You will need to experiment for exactly how long to hold the button.
Here I normally count 1 2 3 release
