27 Feb 2024 11:04 AM
My SKY Q Box is on standby and will not turn on using the remote. I have obviously put new batteries in the remote but still not working.
Can you turn the box on from standby without the remote ?
27 Feb 2024 11:07 AM
Hi @TonyC1967
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
27 Feb 2024 11:17 AM
Amber button will not work either.
27 Feb 2024 11:18 AM
Hi @TonyC1967
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Ordering a new Q box usually means a doorstep swap.
