Discussion topic: not able to download UHD
This message was authored by: Philk2022
Unable to download UHD tv shows and movies, get a message saying to upgrade even tho I have the UHD package and can watch sports channels with UHD
Re: not able to download UHD
Do you also have Sky Cinema subscription @Philk2022 ?
Hi @Philk2022   Have you checked that your resolution hasn't reverted back to 1080p?
Avatar for Philk2022
Yes @oldfella I have it all.
@MightyQuinn yes I've checked the resolution and it's all set to uhd.
Hi @Philk2022
Is your Q box set to 2160p 10 bit as it could be an HDR issue if you are trying to download UHD/HDR content.
You also need a HDR capable Q Box.
@oldfella ye its all set, it was working last week, I've been away and now it's not! I've restarted my box to try and sort it but still nothing 🤔
Hi @Philk2022
@oldfella just done that, nice hack to know but unfortunately still the same message! I've checked everything again, it's so strange 😒
Update Its not just UHD it won't let me download anything, saying I don't have the right subscription to!
Only other thing I can suggest @Philk2022
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
@oldfella no luck, will have to give sky a ring! Thanks for the help! 👍
Hi @Philk2022
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147?.
This message was authored by: Lisa-P1987
Thanks for escalating this. We’ve sent Philk2022 an invite to chat.
Lisa - Sky Tech Team Expert
This message was authored by: Addie15
Update-We are closing this chat now as this matter has been resolved. if you need help in the future, please do not hesitate to reach out. Thanks.
