Discussion topic: no signal on sky mini box is it the weather conditions
This message was authored by: JL297128714GB
the sky mini box in the bedroom is showing no signal so unable to use tv
Re: no signal on sky mini box is it the weather conditions
@JL297128714GB is the message on screen no signal or no satellite signal ?
Hi @JL297128714GB
Reboot the mini as above.
