Discussion topic: no satellite signal
Message posted on 08 Nov 2024 07:35 PM
no satellite signal
no satellite signal says you are working on it since 09.00 this morning what's going on
Message posted on 08 Nov 2024 07:48 PM
Re: no satellite signal
Not sure what you mean by "working on it".
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
