Discussion topic: no satellite signal
This message was authored by: Niall82
no satellite signal
Hi all, my sky q box is saying 'no satellite signal'. Its not a dish issue as the signal comes back for a day or so then decides to disappear again.
All cables etc are in place. No bad weatner.
Any advice?
Re: no satellite signal
@Niall82
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
▪️I AM NOT A SKY EMPLOYEE (not even undercover) ▪️
Avatar for Niall82
Thanks so much for the quick reply. The alignment of the dish is perfect and I've checked  all thee cables etc. I've tried resetting also but to no avail.
Thanks again
@Niall82
I doubt it. It needs to be checked by an engineer. As I said, any misalignment won't be visible to the naked eye.
Avatar for Niall82
OK thanks, I'll book an engineer to get it sorted.
Would it be unusual for the signal to be fine for 3/4 days in a row then 'no satellite signal' for a day then back working fine for anther 3/4 days? Is that indicative of a dish alignment issue?
This message was authored by: ThePope27
If the dish isn't bolted up correctly and the wind is blowing it in and out of alignment, a few mm out can make you lose half your channels
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Avatar for Niall82
Thanks for that. It's losing all channels for a full day and then perfect for a few days.
Just out of curiosity, there isn't anything blocking the line of sight is there ?
You can either eye it, or use an app on your phone called "sat scope" if your not sure 🙂
Avatar for Niall82
Hi,
No it's  up on the 2 storey part of house in a semi-rural area so nothing blocking.
@Niall82,
I would call for a sky engineer to come out, he will use his meter which will check the allignment and your dish is receiving all the transponders.
Avatar for Niall82
Cheers will do and thanks for the quick response.
Just out of curiosity, would that pattern of working fine for 3/4 days then gone for one and back perfect for another few days have any other explanation bar an alignment issue?
Dodgy LNB, Dodgy tuner(s) on the Sky Q box itself, water ingress in the sat cable causing a short circuit, dish just a tad too much out of alignment that the weather is effecting it for example clouds /or rain.
Without seeing your hardware it's hard to pin point it to 1 thing, if it is any of those listed above, the Sky engineer will have it all in his van to sort you out.
On a side note I know you've probably checked but are the satellite cables on the back of your box screwed in tightly ?
