Discussion topic: new Sky Q box with no power cable
This message was authored by: LNS
Our Sky Q box broke last night, Sky have delivered a new box today but with no power cable. The port is different to the old box. They have said that they can't just send a cable, an engineer has to come out and fit it. Is this correct? Can I just buy an adaptor?
Re: new Sky Q box with no power cable
@LNS
It's possible you've received a v2 main Q box which uses an external transformer and that's missing from the package.
These are available from eBay (part number SP170 or SP171) but it's really something Sky should supply free-of-charge.
It's not possible to 'just buy an adaptor' from a 'figure-8' (IEC C7) plug to the orange round plug because the transformer block is the adaptor.
This message was authored by: bob1234
@LNSas @TimmyBGood says it probably needs the power unit, unfortunately Sky rarely supply parts and will probably need to change the box again.
This message was authored by: nicolajmacey
Probably left in the box by courier, just had to ask ours twice to look in the box for a lead and there it was
This message was authored by: CB494
Snap
our sky Q box said their was a problem with the hard drive so ordered what I thought was a new box. It's a refurbished one and it came without the power cable and our cable doesn't fit.
Now we have to wait til 20th May 2024 for a engineer to come out.
Never heard anything so stupid so now without TV til then.
Begrudge paying £25 plus for one off EBay when it should really come with it.
Just thought as well that my remote probably won't work either with a replacement box
@CB494 wrote:
Snap
@CB494 as all the boxes belong to Sky then i would think that now adays all boxes will be refurbished boxes.
The cable would have been in the box the problem is the DPD drivers never check the box  ie under the cardboard for the cable as they just want to swap the boxes over as quickly as possible you did remember to remove the viewing card from your old box ? before giving it to the DPD driver
@CB494 wrote:
Snap
The remote will work
Yeah he was rushing me but don't think there was a cable and i dis remember to take the viewing card out
This message was authored by: SP18
Same problem with DPD driver. No power cable and now no viewing card either what do I do?
@SP18 wrote:
Same problem w@ith DPD driver. No power cable and now no viewing card either what do I do?
@SP18 you will need to contact Sky
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
