Discussion topic: my sky box keeps trying to connect to someone elses router, then I have to reset the connection
This message was authored by: ade6319
my sky box keeps trying to connect to someone elses router, then I have to reset the connection every time, this can happen a few times a week and then there is no recordings on every box, had anyone else experienced this?
Re: my sky box keeps trying to connect to someone elses router, then I have to reset the connection
If your standby setting is on Eco, try changing it to Active.  To do this, go to settings, then select Setup, then Preferences. On the right look to see what your Standby mode is. If it is Eco or None, change it to Active. If it is already on Active, then your problem isn't to do with your Standby mode.
