Discussion topic: my multi room sky box is not working
This message was authored by: Susangriffin
multi box is not working in bedroom
Re: my multi room sky box is not working
@Susangriffin
What's happening? Any error message? 'Not working' doesn't give us a lot to go on.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Susangriffin
Hi multi room box is not connecting to main sky box
@Susangriffin
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
