Discussion topic: mini box only works when main box is not in use
Message posted on 31 Dec 2024 11:50 AM
Mini box is ok when the main box is not in use. When main box is switched on connectivity is lost with mini box, Help!
Message posted on 31 Dec 2024 12:02 PM
Re: mini box only works when main box is not in use
Hi @RB151
Reboot the mini as above.
