4
This discussion topic has been answered Discussion topic: lack of Sky signal
This message was authored by: Pickychook
lack of Sky signal
Our Sky TV has suddenly had the no singal message. I have gone through all of the instructions but still the button on the box is amber. yet I can get the adverts about Sky.
Re: lack of Sky signal
Hi @Pickychook
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Hi @Pickychook
Avatar for Pickychook
Level 2 icon
Thank you for that. We can get netflix , prime etc. Does that mean anything please.
Hi @Pickychook
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Level 2 icon
Thank you so much for your help.
Answered - Go to Answer
