Discussion topic: it says on my tv i dont have internet connection but wifi is working
This message was authored by: AbbieCosnett
it says on my tv i have no internet connection but the wifi is working
Re: it says on my tv i dont have internet connection but wifi is working
hi @AbbieCosnett
Assume this is your main Q box and not a mini.
