2
This discussion topic has been answered Discussion topic: iPlayer app on my skyQ box will not work
This message was authored by: HPuser99
I've tried the reset settings instructions suggested in previous threads but this has made no difference.   Everything else works, but the iPlayer app has failed to work for nearly 4 weeks.  I get nothing but a blank screen - no error message or any other prompts.
Re: iPlayer app on my skyQ box will not work
Hi @HPuser99
Have you tried refreshing the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Hi @HPuser99
Select Apps 
Avatar for HPuser99
I was about to write that didn't work.  But after 24 hrs, and then waiting about 10 mins I finally got the screen saying please use your mobile phone and this code.
thank you @oldfella
