6
This discussion topic has been answered Discussion topic: i have just moved home and my Sky Q box has been lost how do i get a replacement
This message was authored by: Gmac
This message was authored by: Laing1 Answer
Re: i have just moved home and my Sky Q box has been lost how do i get a replacement
@Gmac you will need to speak to Sky but they will probably charge you for a replacement box I have escalated this to sky i need to wait for 10 minutes before I send it through to Sky
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
If you are using the Safari browser please make sure that Hide IP Address is not checked in order to see the chat bubble. If you are having trouble finding this to check the settings, use another browser such as Firefox, Chrome etc.
The link below explains how the escalation process works
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Gmac
Level 0 icon
thats fine i have no problem paying for it i just cant seem to find a number to call to order it
@Gmac
Remember if that's a main Q box you're also going to need a new Viewing Card, and you'll need to check with whoever you speak with that they've ordered this.
Also, make sure they have your new address...
@Gmac II have escalated this so hopefully Sky will contact you on here
@Gmac
Oh, and if the new address hasn't had Q before, you're going to need a Home Move booking.
This message was authored by: Lisa-P1987
Hi there, thanks for the escalation. Unfortunately this is not one we would be able to support as it will likely require a payment which our team cannot sort.
The best thing to do is to begin the home move process, in which a box can be
https://www.sky.com/help/home/sky-tv/sky-tv-q/setting-up-sky-q/set-up-sky-q-box/articles/setting-up-...
If you follow this link above to the end and then pick the "no I still need help" option, it'll present you with contact info.  The team can arrange the box, and card and engineer if needed.
Lisa - Sky Tech Team Expert
