3
This discussion topic has been answered Discussion topic: how to order a new sky q box
This message was authored by: sueallen53
I have be having problems with sky q box either not recording , watching recordings and freezing and remote problems I reset it all and works fine for abit then does it all again
do I need a new box
This message was authored by: PandJ2020 Answer
Re: how to order a new sky q box
@sueallen53 wrote:
do I need a new box
Possibly - any messages about hard drive issues?
@sueallen53 wrote:
do I need a new box
Avatar for sueallen53
we have had hard drive issues and we have done what they have suggested and its ok for a while and then does it again. I just wondered if we might need a new sky q box
If the HD is failing then it may work for a while after resetting and then fail again.
Follow this, but I suspect you'll need a box swap: https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
