8
This discussion topic has been answered Discussion topic: have sky q and hybrid lnb can i use old hd box upstairs
This message was authored by: montyfert
hi i have sky q downstairs , i have a hybrid lnb and a spare sky plus hd box, can i watch and record on the hd box if i connect it and put it upstairs .
thanks
martin
This message was authored by: nigea99 Answer
Re: have sky q and hybrid lnb can i use old hd box upstairs
thanks
martin
hi @montyfert
If you have a hybrid LNB & the 'Universal' outputs are connected to the leads where you want to use the SKY HD box then you can use the  the SKY HD bx to watch the Free to Air channels.live
You can't use the SKY HD box to record anything or to watch SKY channels once the account was switched to SKY
@montyfert simple answer is no you can't the lnb doesn't support older boxes and sky no longer sells subscriptions to any legacy services including recording functionality
Avatar for montyfert
thanks
martin
its a hybrid lnb so it should
thanks
martin
hi @montyfert
sorry , its a hybrid lnb so it should work with the sky plus hd box.
@montyfert have you read @nigea99 post the one directly above yours it was posted around the sametime as you posted your last post so you may have missed it
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
yeah just missed it
thanks
thanks
martin
@montyfert
Recording is a subscription feature, and once there's a Q subscription at the address then any HD hardware is no longer covered by one.
The Q subscription also doesn't provide any non-free-to-air reception on HD hardware.
