8
Discussion topic: have sky q and hybrid lnb can i use old hd box upstairs
This message was authored by montyfert This message was authored by: montyfert
hi i have sky q downstairs , i have a hybrid lnb and a spare sky plus hd box, can i watch and record on the hd box if i connect it and put it upstairs .
thanks
martin
This message was authored by nigea99 This message was authored by: nigea99 Answer
Re: have sky q and hybrid lnb can i use old hd box upstairs
thanks
martin
hi @montyfert
If you have a hybrid LNB & the 'Universal' outputs are connected to the leads where you want to use the SKY HD box then you can use the  the SKY HD bx to watch the Free to Air channels.live
You can't use the SKY HD box to record anything or to watch SKY channels once the account was switched to SKY
This message was authored by SKY1992bf This message was authored by: SKY1992bf
@montyfert simple answer is no you can't the lnb doesn't support older boxes and sky no longer sells subscriptions to any legacy services including recording functionality
Please note: I am just a sky customer not a employee - posts from sky employees are clearly marked as such
montyfert
thanks
martin
its a hybrid lnb so it should
thanks
martin
hi @montyfert
montyfert
sorry , its a hybrid lnb so it should work with the sky plus hd box.
This message was authored by Laing1 This message was authored by: Laing1
@montyfert have you read @nigea99 post the one directly above yours it was posted around the sametime as you posted your last post so you may have missed it
montyfert
yeah just missed it
thanks
montyfert
thanks
martin
@montyfert
Recording is a subscription feature, and once there's a Q subscription at the address then any HD hardware is no longer covered by one.
The Q subscription also doesn't provide any non-free-to-air reception on HD hardware.
