5
This discussion topic has been answered Discussion topic: get rid of the pin!
This message was authored by: rachyg595
get rid of the pin!
Hi folks, any idea how to get rid of the need for a pin on sky cinema please? ive turned the need for it off everywhere that i can see. my kids are 18 I really think they can watch18+ movies before 8pm! thank you in advance
Re: get rid of the pin!
Hi @rachyg595
Afraid pin is going to be required in some instances.   Best to set it to something simple.
https://helpforum.sky.com/t5/Sky-TV/Is-there-any-way-I-can-turn-this-damn-parental-control-off/ba-p/...
Hi @rachyg595
You can't as it's an Ofcom requirement (mandatory daytime protection).
Avatar for rachyg595
Gah how annoying! thank you for replying
This message was authored by: Invisiblename
@rachyg595  Change your PIN to something simple like 1111, makes it very simple
I am just another Sky customer!
great tip, changed to 0000!
