Discussion topic: connecting q box to wifi
This message was authored by neilhorse This message was authored by: neilhorse
Just got new qbox and multiscreen box after sending old ones back.
Problem now is that I can't connect any box to my sky wifi using WPS button. I've also tried connecting using my sky password (non sky router). All other household devices working correctly and no connection issues Tried the reset buttons and am now waiting for a week for an engineer visit. Any thoughts , so as I'm not waiting a week
TIA
This message was authored by Colin0000 This message was authored by: Colin0000
Re: connecting q box to wifi
TIA
What do you mean by non Sky router? Are you using a 3rd party router for WiFi and disabled the Sky router WiFI? If so you should be using the WiFi password for the 3rd party router.
Sky Q 2GB 32B106 - HDMI to TV, hard wired to router with WiFi disabled on the Q box
VM 256Mbps via rubbish VM HUB 3 router
Samsung S95C 55"
neilhorse
I meant to say  i've tried both the sky router way on screen using the wps button and also tried picking the non sky router (which it isnt) to try to enter my password
Moderator note: Removed third party link.
This message was authored by Laing1 This message was authored by: Laing1
TIA
@neilhorse just for information the Q boxes will only connect to a Sky router by way of the WPS button
have you tried a network reset in the settings on the main Q box
neilhorse
I'll try that when I get home
