12
Discussion topic: connect homepods to sky Q
This message was authored by ilovemyprobe This message was authored by: ilovemyprobe
I have Sky Q along with a Panasonic TV (has 3 HDMI slots) and a pair of Apple Homepds. I am looking to play the TV audio through the Homepods when Watching Sky Q. I figure I will need to buy apple TV?
Once I have purchased an Apple TV Box and connected it to my Panasonic TV, will I then be able to just watch Sky Q and have the sound from Sky Q delivered to the TV which will then feed the audio to the Apple TV to then transmitt stereo to a couple of paired homepods?
Or will i have to watch everything directly through the Apple TV in order to gain sound via the Homepods?
Can someone kindly answer this, thank you.
This message was authored by PandJ2020 This message was authored by: PandJ2020 Answer
Re: connect homepods to sky Q
Some info here: https://www.macrumors.com/how-to/play-audio-from-tv-inputs-homepod-apple-tv/#:~:text=ARC%20(Audio%20....
If you connect the AppleTV to the TV's HDMI socket with (e)ARC then any audio on the TV (e.g. from the Q from a different HDMI input) should be sent to the AppleTV which can in turn send to the Homepod(s).
I am just another Sky customer and my views are my own
