Discussion topic: can't connect mini box to main
Message posted on 20 Sep 2024 10:40 AM
Changed braodband ,main box is connected ,can't connect mini boxes ,
Message posted on 20 Sep 2024 11:37 AM
Re: can't connect mini box to main
Hi @RB100
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
