Discussion topic: can't access recordings & mini boxes not receiving signal
Message posted on 13 Jun 2024 09:21 AM
Hi,
My main Sky box won't list the recordings I have made.
Also, mini boxes showing "No satellite signal"
Message posted on 13 Jun 2024 09:26 AM
Re: can't access recordings & mini boxes not receiving signal
@Trevorsr You're post has been moved fromthe Sky Talk forum as this is for Talk lindline issues not a place to talk to Sky.
Have you tried unplugging both Main Q box and mini, then plufg in main q box, allow to fully reboot and do the same for the mini.
Message posted on 13 Jun 2024 09:29 AM
Yes - unplugged everything - message last night suggested "problem with harddrive"
Message posted on 13 Jun 2024 09:30 AM
Hi @Trevorsr
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
