Discussion topic: box min technical faulf no sky cant play recordings
This message was authored by: keanu
Message posted on 07 Mar 2023 06:19 PM
box is not working can get sky any tv cant olay recordings
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 07 Mar 2023 06:24 PM
Re: box min technical faulf no sky cant play recordings
@keanu Have you tried rebooting your main Q box ie
then
do the same with your mini box
