Discussion topic: bbc iplayer stops in the middle of a programme
Message posted on 01 Mar 2025 08:51 AM
BBC iPlayer has a habit of stopping in the middle of a programme and switching off. This happens randomly, sometimes after an hour, sometimes a little longer. Any ideas?
Message posted on 01 Mar 2025 11:43 AM
Re: bbc iplayer stops in the middle of a programme
@SaraT Have you tried rebooting your main Q box ie
if that doesnt help
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 01 Mar 2025 03:31 PM
Thank you, Laing1. I had tried resetting the Sky box before, also my modem, but none of that worked. I am now trying your suggestion for refeshing the apps to see if that will work.
Message posted on 03 Aug 2025 10:47 AM
Did this fix your problem?
I have the same issue 😥
iPlayer through my Samsung TV is fine, but iPlayer through the Sky Q box and it goes blank after about an hour, box is still on.
By any chance do you have a Samsung TV as well?
Message posted on 03 Aug 2025 06:44 PM
We have a pretty old Sony TV.
We still have the problem, but intermittently. It is very frustrating. I have seen other threads that suggest it is the Sky Q box which causes the issue. I did try resetting the apps, some time ago, but it didn't make any difference😡
